Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Drywall thickness on ceiling with 24" centers...
Old 03-09-20, 07:36 AM
I have a new build addition with 24 inch center trusses. I'm getting ready to hang drywall and not sure what thickness would be best. I have 19 inches of insulation in the ceiling which seems a little heavy seeing the insulation is sagging down below my ceiling trusses and the drywall would have to push up on it. I noticed the drywall Home Depot has all says "Ultralight" extremely lightweight and weights up to 30% less than regular drywall, I'm afraid that Ultralight 1/2 inch may sag being 24 inches apart pushing up on the weight of the insulation, should I use 5/8 drywall instead?
Old 03-09-20, 07:40 AM
P
Received 526 Votes on 483 Posts
I've always seen 5/8" used with 24" joist spacing.
Old 03-09-20, 08:14 AM
Received 260 Votes on 230 Posts
I agree, 5/8" is best for ceilings and the only good choice when the ceiling joists are on 24" centers.
Old 03-09-20, 03:57 PM
XSleeper's Avatar
Received 570 Votes on 523 Posts
Yes, you never use 1/2" if its 24 on center and will have insulation laying on it.
Old 03-09-20, 08:10 PM
Received 94 Votes on 83 Posts
Yep, has to be 5/8" with that spacing. 1/2" is only ok with 16" OC.
Old 03-10-20, 04:58 AM
Thanks guys, I'll order 5/8" for the ceilings
Old 03-10-20, 05:18 AM
Another quick question, what length drywall screws are best for hanging 5/8" drywall?
Old 03-10-20, 06:13 AM
XSleeper's Avatar
1 5/8".................................
Old 03-11-20, 03:55 AM
Thanks again guys
