Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Making a vertically sliding TV wall mount
Old 05-15-20, 03:33 PM
B
Lightbulb Making a vertically sliding TV wall mount
Hi all
I have an issue where my TV Wall Mount is mounted quite high on the wall, and mounting it lower would inflict on the dinner table. I therefore want to make a Device which allows the TV to be slided vertically along the wall.
My idea is visualized in the Attached PNG photo. I want to use 2 linear slide and a threaded rod to guide the TV Mount vertically. A wooden panel is the Interface between the vertical slide and the original horiztonally sliding TV Mount.
I am looking for feedback from experienced DIY-ers whether my concept is realizable and any pitfalls to look out for.
Regards
Borge
Old 05-16-20, 05:26 AM
P
Received 524 Votes on 481 Posts
The only problem with threaded rod is turning it. How will you turn the rod to raise and lower the tv? If you want a automation project then you can motorize it but if your TV is smaller then I'd just manually raise and lower it, maybe with a pin going into holes to lock your height. For me I'd probably do a 50" or smaller manually and motorize for anything larger.
