Resilient bar a bit loose?
Old 06-03-20, 05:11 AM
Q
Received 1 Upvote on 1 Post
Hanging some resilient bars for the first time. I'm attaching them on the thick metal flange but this leaves the other side loose by design. The other side seems to move a bit with weight so I don't understand how they can support drywall?
Old 06-03-20, 05:25 AM
P
Received 1,846 Upvotes on 1,653 Posts
What is a resilient bar? Is this the strips used to mount sheetrock for soundproofing? If it is they must move a bit. It's their job to isolate the movement of the sheetrock from the studs. I've never used them but I imagine it will all firm up when you get the entire wall sheet rocked.
Old 06-03-20, 05:32 AM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Thats how and why it works. You install rc channel perpendicular with 1 screw per joist. Once you screw sheetrock to it, its flat and evenly 1/2" below the joists. You dont screw through the drywall and into any wood or you defeat the purpose. The leading edge is loose but the next one picks up the weight of the drywall so that the last one doesnt sag. Drywall is flat. So all the rc channel will be flat once you screw it all together.
