Garage drywall question
Hello,
I am having a detached garage built and one of its walls will require fire-rated drywall and corresponding Rockwool-type insulation (this is because this side of the garage is less than 5-feet from neighbor's property line).
I intend to drywall and insulate the remainder of the garage's walls and its ceiling too. Will use fire-rated drywall and standard faced insulation for this portion of the garage. I intend to have a 4000 BTU electric heater in the garage to heat it in the winter months (live in lower portion of Michigan and will only heat the garage when I am going to perform work in it).
My question is, because the Rockwool fire-rated insulation is not faced, should I use some type of vapor barrier over it before installing the interior drywall.
Local building code requires that exterior side of garage stud must have fire-rated drywall over it too, but in my opinion I don't think it would be necessary to put vapor barrier over this side of Rockwool Insulation.
Thank you.
Thank you.
On a detached garage that is only heated part time, I dont think you need to worry about a vapor barrier. But you are kind of at the mercy of your building inspector. So if you want to make sure I would make a call to their office and ask if it is required. If it was a house, and heated fulltime, it would likely need one. A garage... IMO its doubtful.
Wolverine77 voted this post useful.
"I intend to have a 4000 BTU electric heater in the garage..."
I don't think your heater will have a snowballs chance especially in a large space with only one wall insulated. You haven't said the size of your garage but a 50'000 btu jet engine style heater often seems under sized in an uninsulated two car garage.
Not really sure why the wall requires insulation, beyond the fact that it will be fire retardant type such as Rockwool. Only reason I can think of is that it adds another layer of fire protection.
