Peel and stick flooring
About a year back I used peel and stick flooring on the walls above a shower stall where the 30 year old wall paper had to be removed. Yes, the packaging said the tiles were intended only for the floor.
About 18 sq ft total, 9 tiles, trimmed them to the corners and job looked good. Then it became obvious the adhesive was not drying or holding the panels tight to the wall. I used a piece of trim to hold the panels to the wall about 8 inches from the ceiling and all looked fine for a while and the panels began to buckle between the trim and the top of the shower stall.
My two choices seem to be to find another adhesive that could be added to the factory adhesive to affix the tiles and brace them using a pole from the adjacent wall until the new adhesive dries or just remove them all, clean off the original adhesive and put up a textured, paintable wall paper.
Thoughts, comments, ideas would be helpful.
A shower is a tough environment with lots of humidity and rapid temperature changes. Very tough on vinyl which expands and contracts a lot with temperature change. I would stick with materials recommended for a shower or an indoor/outdoor environment.
I've used construction adhesive (liquid nails or similar) to stick peel-and-stick tile to places that needed extra adhesive. Since it's on a wall, you'll probably need to use masking tape or blue painters tape to hold them up while the adhesive dries.
I don't think it's a great idea to use vinyl tiles in the bathroom, but it should work.
Thanks to both of you. I have ordered a roll of textured paintable wallpaper and I think this will be the easiest way to go.
