5/8 drywall or cement board?
Just put up a new addition and I have a boiler and h/w heater closet on the first floor. Should I just use the 5/8 fire rated drywall inside the closet or should I use heat cement board? Thanks...
Cement board or Hardi are not approved fire proofing materials as far as I know. They are not flammable but their cement composition readily transmits the heat of a fire through a wall. The water chemically bound in gypsum (sheetrock) is liberated by a fire's heat. The escaping steam/water vapor provides dramatic cooling which stops the heat of a fire from getting through a wall.
Zorfdt
voted this post useful.
I'm going to use 5/8 drywall on my walls and ceiling as you suggested, I just have one more question about my flooring. I have 5/8" T&G flooring in my boiler closet, should I use some kind of cement board to put over the wood floor or am I safe to just set the boiler on the wood sub floor?
I did a search for "boiler catch pan" and found a bunch of rectangular catch trays. Most don't say they are for boilers but if you measure your boiler it looks like you have a good chance of finding a catch pan that will fit. Most are plastic so there won't be any fire protection and I'm sure it will be fun lifting the boiler while someone slides the tray underneath.
I'll have to check around and see what I can find. Seeing the burners are usually located on the bottom of a boiler but they are enclosed inside the metal boiler jacket it self, I was just looking for a little extra protecting seeing it would be sitting on a wood floor, just a little extra protection to keep the heat off the floor, better safe an sorry.. ...
