Access door won't fit between studs
Old 11-12-20, 08:20 AM
B
Received 1 Vote on 1 Post
I bought an expensive access door to cover a hole in the drywall made by the previous owners to install custom bathroom plumbing. The access door frame is 14.5 inches wide and extends in 1.25 inches but the distance between the studs is only 14 inches. Is there a way to shave a half inch off one of the studs? It's too late to return the door.
Old 11-12-20, 08:26 AM
P
Received 858 Votes on 791 Posts
I assume the door is on the surface but has a frame that extends back into the wall and is hitting the studs. I would cut off whatever of the door's frame that is hitting the studs. You probably only need to cut off the vertical part while the horizontal can be left.
Old 11-12-20, 08:27 AM
T
Received 16 Votes on 14 Posts
It's more work but to maintain more strength I would shave 1/4" of of either side. I've had good luck using an oscillating tool for this kind of work. And you probably don't have to shave off the full width of the stud Any way the door can be remodeled?
Old 11-12-20, 08:46 AM
B
The door is made of steel and I can't modify it. I understand that taking 1/4" off each side is a better idea. I've never used an oscillating tool but there are YouTube videos for everything. Would a $100 DeWalt oscillating tool come with the right attachments for what I need to do?
Old 11-12-20, 09:15 AM
2
Received 92 Votes on 78 Posts
1/4 inch is not so much that you would need a saw. You can cut 1/4 inch into the studs at top and bottom of the opening and chisel out the middle.
Old 11-13-20, 06:54 AM
W
Received 32 Votes on 29 Posts
Use a circular saw:
1. Mark the cut line on the wall surface.
2. Set the depth of cut on your circular saw.
3. Make the cut.
4. Remove the waste wood with a wood chisel.
5. Install the door.
Old 11-13-20, 08:05 AM
B
Thanks to everyone who responded. I went to Home Depot yesterday and was amazed at how disorganized the power tools section was. Of all the different tool brands they carry the only oscillating tool I could find was a corded Dremel. It seems simple to use but nothing is ever as simple as it seems. I'll report on how the job went when I finish.
Old 11-13-20, 11:39 AM
Norm201's Avatar
Received 341 Votes on 307 Posts
I like 2John's answer. A 1/4" will not affect anything and no special tools short of a chisel is needed.
Old 11-13-20, 01:09 PM
2
Unless you need an excuse to buy a useful tool...
ferd42 voted this post useful.
Old 11-16-20, 03:39 PM
B
The oscillating tool worked perfectly. A job that has been an annoyance for a long time is finally done.
Old 11-17-20, 10:37 AM
T
Thanks for letting us know how things worked. Too often we never learn if our advice was taken or if it was good advice.
