trying to ascertain if this wall is load bearing.
florida block home, built 1995
wall originally had upper.lower cabinets/stove and stove vent
single plate at the top
i have never seen trusses like these, hence the inquiry.
picture 4 is mislabeled, just showing the downward wood spanning the home.
picture 4, where is states wall to be removed is exactly in the middle of the wall ins question.
Welcome to the forums!
Normally when trusses span the width of the home none of the walls below are load bearing, just the walls at each end of the truss. What makes you think the interior wall in question is load bearing?
None of the photos give a very clear picture of the entire shape of the complete truss, and they don't clearly show if all the trusses are exactly the same or if there are different types.
The left side of the truss in photos 1 and 2 do not appear to be a mirror image of the right side. That makes me concerned that the wall in the center IS load bearing.
Photo 3 also seems to show a different style of truss not seen in any other photos.
the wood pieces coming down from the actual truss are they for drywall only or do they carry a load?
The entire thing is the "actual truss". They work as a unit, parts under tension parts under compression.
Like I said, without being there and seeing a complete diagram of the truss framing layout, it is pretty hard to say. There are lots of truss shapes, and all we can see in your photos are incomplete pictures of what a few of the trusses look like. No drawings of a complete truss. No blueprint of how they are laid out or where girders are. They work as a system, there are sometimes load bearing walls, sometimes not.
What Marksr says is correct, that typically only the exterior walls are load bearing. But without being there, its pretty hard to say with 100% certainty.
Gable or hip is the style of the roof, yours appears to be a gable. The truss is separate from any walls. If there is a load bearing wall it would span under multiple trusses. I used to paint a lot of new construction block homes in fla [70s & 80s] I don't recall any of them having a load bearing wall, the trusses were supported by the block wall on each side. Is this house in a subdivision built by the same builder? If so, the neighboring houses would likely be constructed the same way and a neighbor might be able to help you.
There are many kinds of trusses. See link. While most bear at 2 points (usually the exterior walls), some bear at 3 points. We cannot tell everything from just photos, from 1000 miles away.
That being said, load bearing walls typically have a double top plate. So what i see in your last 2 photos is probably not load bearing. You would not have a load bearing wall with a single top plate and studs that are not directly below the trusses.
That being said, you almost always want to have a structural engineer or someone qualified, look at any structural changes in person.
where the truss comes down and goes straight (white paint) , it hits a load bearing beam that spans the outside wall.
This is not clear at all. There is a ton of white paint in the photos. The "truss" is all the framing that is connected with metal plates. And i see no "beam" in your photos.
I'm remodeling 2 bathrooms in my house because of long term moisture damage. I'm not doing these projects myself, but at least want to understand the process and learn along the way. After researching here as well as other sites, I'm trying to figure out the type of drywall to put in my bathrooms. Seems there are just as many opinions as when asking what is the best oil at a car forum. We will not have tile in the shower so water will not be hitting any walls directly...just a standard fiberglass (or whatever it is) shower stall. I can say moisture is the major concern. I'll be upgrading my fans but I have 3 teenage girls who in the mornings take hot shower..after hot shower...after hot shower.
From what I read so far I'm leaning toward the green backed drywall in the entire room including the ceiling..but I welcome opinions if I'm way off. Thanks in advance
Hey guys, I have this speaker here:
[url]https://av.loyola.com/products/audio/ev-eliminator-i.html[/url]
I would like to hang it lying flat and facing downwards from as close to the ceiling as possible in my Garage. 2 problems, the wall is hollow brick and the ceiling has 60 year old beams as that is the age of this garage. Please see attached pic, the red arrow area is where I would like to hang the speaker between those 2 shelves on the left and right:
[url]https://i.postimg.cc/fT2DrCMj/IMG-2242.jpg[/url]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/speaker_e3e250c84a1e969f843ab7217bf3ea3d32403646.jpg[/img]
Can you guys advise on the simplest secure way to this please? Thx.
