An upstairs shower seal around the floor gave out and resulted in a leak to the downstairs. I have to repair the portion of the ceiling downstairs and need some help on matching the texture so I don’t have to redo the entire ceiling. Can anyone help me with how to get this texture. Should only be on about a 6x4 foot section that needs to be textured. I have no experience with ceiling repair but this is a project that I feel like I can handle and just hoping I don't completely mess it up.
Reason: More inofrmation
Well, we can tell you how to get a texture pretty close to what you have. Are you going to replace the plaster or drywall or will a simple scrape and retexture be all you need?
This looks like a simple stomp texture. There are all kinds of ways this was done. Basically some mud was mixed to a thin like pancake batter consistency then some kind of a tool was dipped into that mud and pressed quickly with some force against the ceiling and pulled away. There are special tools made called crowsfoot brushes to do this. Your texture looks more like it was done with a sponge or maybe a piece of shag carpet nailed to a board or maybe even a wadded up piece of plastic. The best advice is to get the ceiling nice and flat and smooth then experiment with different consistencies of mud and different types of stompers until you get it. The experimenting can be done on scraps of drywall. You can try something then if it is close enough use that on the ceiling. If it is not close, then scrape off what you did before it is dry and try something different. The variables are the tool and the consistency.
Have fun, experiment, get the ceiling right first. I am looking at the ceiling in the room I'm in. It looks a lot like yours. I used a plywood disc and some foam padding on that then a couple layers of burlap bag on that There is a handle in the middle on the bottom. I got the mud to the consistency I liked then dipped the stomper and hit it in expanding areas three or four times per dip then dipped again and kept going until the lid was done. After it was dry I shaved off some of the high, rough spots with a trowel. Took longer to cover the floor and mix the goop and wash the stomper than to do the ceiling.
Others may have other ideas about what tool to use. Some advise painting or at least priming first then texturing. You have more than one chance at this if you wipe off your attempt if you don't like it before it's dry. Sorry this got so long.
I should have made the stomper I described just a little smaller. It won't fit all the way to the bottom of a bucket. I had to get a large dishpan to hold my texture mud.
I've watched the process done and it's fascinating. I was checking out some videos on this work and found one where the guy used a roller to roll (stiple) the mud first. Then he used a stomper. I think it looked better before he stomped it.
I've spent so much time perusing forums and sites about the ifs, and buts, about nail pops and drywall cracks but can't wrap my head around the numerous things going on at the same time in this house. Or...maybe I'm crazy. Over the past 3 or 4 months numerous, probably 3 dozen or so nail pops spanning both stories of the house have started to show. I have 3 doorways and hallways that have vertical cracks, no diagonal, over them. Some seem like paint/board is crushed above the moulding. I have 3 windows that have a vertical crack underneath them. The basement has a floor crack I filled in probably 2 years ago near a steel beam (basement is unfinished) has separated slightly. What I don't seem to have is sticking doors, windows, etc. I don't have any large cracks on the basement walls. Those cracks I do have down there are hairline and vertical. All this in a short time doesn't make sense to me to be settling in a 14 year old house (built in 2007). Am I over stressing or should I be calling someone out to look at this, and, if so, who?
I posted a month or so ago where a tree fell into and ripped the basement walkout rail out of the concrete on one side (just noting, don't know if it's related).
This may be a loaded post but I'll do my best to keep it clear. We are in the process of finishing my basement. I have found a mudder/taper who comes with high reviews. I have done all of the work in my basement myself thus far (framing, HVAC, electrical and plumbing) and have had all of the proper inspections done by city and state. This particular guy doesn't hang drywall so that's on me, which comes with some questions I'm looking for answers/advice on. All rock will be 1/2" ceiling & walls and 4'x8' sheets due to access to basement.
1) Horizontal or vertical? Or is this situation dependent? The majority of my outside walls have a framed out half wall. This wall is 37". From wall to ceiling is 60". As you can tell ny ceiling is 8'1". I believe it would make the most sense to run vertical with these walls as a 4x8 sheet can run the lower and cut the remaining for the upper.
2) With 4x8 sheets running vertical in these areas, do I need to install any sort of blocking for vertical seams between 16" studs?
3) For the bathroom, I will be installing cement board where the shower stall will be. Do I need to put mold resistant sheetrock in the rest of the bathroom or is regular rock OK?
4) I've read a lot of varying opinions on screw placement for drywall. Is there one specific way that is generally recommended?
Sorry for all of the information and questions. I just want to make this as easy and smooth on this guy as possible. Thank you!
