Durock Screws possible fail?
Old 03-27-21, 05:32 AM
T
I put on a piece of durock for my fireplace, but then had to remove it and flip it over because I didn't have the seam edge at the fireplace opening, I had the cut edge. It looked nicer, but now I realize I need to get at the electrical wiring behind the durock to allow the inspector to see it in order to pass inspection. How many times can I unscrew and re-screw durock before the "anchoring" is weakened excessively? Thanks so much in advance!
Old 03-27-21, 05:48 AM
Marq1's Avatar
Received 1,141 Upvotes on 1,034 Posts
If it was in a wet area where the finish would be scratched off I might have a minor concern, anywhere else, no concern!
Old 03-27-21, 05:49 AM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
You can always put screws in additional places. It all gets mudded over when you tile so all that matters is that it is secured to the wall tight.
