Spray Foam for Noise Reduction
Old 05-07-21, 02:52 PM
H
HELP!! My neighbors sound like a herd of elephants... Does anyone have info. on retrofitting a shared s water wall with spray foam?? How messy is it? What kind of preparation is needed for their unit?
Old 05-07-21, 05:37 PM
Received 3,884 Upvotes on 3,481 Posts
Welcome to the forums.
Spray foam can be dangerous if not used/installed properly.
It expands as it dries so care must be taken to not blow the wall open.
Is this a wall between you and a neighbor ?
Is this a proper apartment/condo situation or a converted house ?
A proper apartment should already have insulation in the walls.
Most apts/condos are double sheetrocked for fire stop too.
Old 05-08-21, 12:42 PM
T
Received 48 Upvotes on 41 Posts
What do you mean by water wall? Is this the wall that has the plumbing for both units? And you can't do much on their side unless they cooperate, which they might. Maybe they think you are loud too? Then you can both work it out.
Old 05-10-21, 03:25 PM
R
I have personally "plumped" the drywall on a wall cavity by filling it with spray foam, and would advise against it.
