My old house has acoustic tile ceilings in every room. I hate acoustic tile because it can't be cleaned. Cobwebs stick to it like glue, and it gets stained from cooking. It also falls down easily. So it's time to put up something else.
I want to start with one room where about a third of the tiles have already come loose or fell off. It's a storage room and I don't really care what it looks like, I just want it to be light enough that I (an elderly woman with a bad back) can do it easily by myself, and as inexpensive as possible.
One material I am considering is Glasliner wall panels. I read about something that sounds even better (easier to install) that's called Duraclad interlocking PVC panels but can't find a dealer nearby. I also thought of using some thin wood panels, or something called PVC Beadboard. I won't even consider using drywall.
What would be the easiest and cheapest lightweight thing that will do the job? What else do I need to know?
Is this something you are attempting to do solo ?
You need to consider the weight and fastening method to your new ceiling.
Sheet goods will have seams.
The 1' square splined tiles are an easy one man installation.
Almost everything else will need at least two people.
Glasliner wall panels come in 4'x8' sheets and gets glued in place.
Duraclad interlocking PVC panels are very expensive and not easy to install.
Take a look at Armstrong ceiling products, many different styles. We have these country planks thoughout the basement and the kitchen. Good looks, cover up ugly drywall, easy to install.
I want to paint my room, but before I do so, I would quite like to flatten my walls to a smooth texture. What is the easiest way to do so? Can I flatten it? Is there some sort of filler I can spread on top of it? Whatever is the cheapest and easiest. Thanks all.
Hello, I just took down a wall between the kitchen and dining room. See photos.
1) First photo below: On the photo showing the wall section adjacent to pantry shelves...I need to extend the wall by another half inch to match cabinets to be installed. You can see in the photo that there is drywall attached. To extend this wall section out another 1/2 inch, can I just tack on a second layer of drywall or should I take off the drywall currently there and put up a slim wood board and then attach the drywall piece? This is a question of whether I can double-up the drywall boards when needed or if I need the support of a wood board.
2) Second photo showing the ceiling with crown molding...same question. There is drywall attached but there is a large gap between the drywall to the crown molding. Can I just tack on another layer of drywall to fill the gap before mudding?
Thanks to all.
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_2673_c2dc091d60bfe23c22d4197d5b34056ceaa9b7ee.jpg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_2674_749bff419f9f659197d831bab9c0afbb68d9b14a.jpg[/img]
