Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Sagging ceiling in the corner of my screened in patio - help!!!
Old 11-28-21, 04:34 PM
B
Hi. Just as the title says - not from water damage. I don't even know who I should call to try to fix it. Handyman, drywaller, or ???? I had a 'handyman' out for this very same issue a few years back. All he did was add some nails to the area - which worked at least until now.
I am clueless as to even how to ask for help for this.
Thanks.
Old 11-28-21, 05:03 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
Kind of looks like you need to put a 1x2 or piece of trim up there to hold it up.
BJP91 voted this post useful.
Old 11-29-21, 02:05 AM
Received 759 Upvotes on 664 Posts
I agree. I assume that is a drywall ceiling and moisture has deteriorated it some where nails/screws in that corner will no longer hold well. A 1x2 along the perimeter should hold it in place.
Old 11-29-21, 04:56 AM
P
Received 1,852 Upvotes on 1,658 Posts
I agree a support strip around the perimeter and more fasteners in the field area to distribute the weight.
What I don't like to see is your hanging hook in the corner came down with the ceiling. That means the hook was not into the structure above and the weight of the plant or whatever you hung was also trying to pull the ceiling down.
Old 12-06-21, 07:08 AM
B
Didn't get a notice of these posts until today - not sure why the delay.
Pilot Dane - The pic is a bit misleading, in that the hanging hook isn't from the ceiling. It is affixed to the brown support beam. I didn't realize how it looks until you pointed it out.
The one and only handyman I have found so far agrees with everyone here - additional screws in the drywall and a support strip around the perimeter attached to the support beam to help hold up the ceiling. He said that the drywall doesn't appear to be damaged enough to replace that piece.
