Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
What strength magnet for finding metal studs?
Old 12-17-21, 07:29 PM
B
Received 5 Upvotes on 2 Posts
I have a music rehearsal space and the management says the rooms are framed with metal studs. I tried using a magnet previously to find them with no luck. I'm guessing I needed a heavy duty magnet. Any recommendations on how much pull of a magnet I should get?
Old 12-17-21, 09:48 PM
Received 3,485 Upvotes on 3,128 Posts
If you do a search you'll find many different metal locating magnets.
This is the one I carry.... it works fantastic.
You just roll it over the wall........ it sticks to screws, nails and metal studs.
Rack-A-Tiers 52300 studball
Old 12-17-21, 11:18 PM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
Or any conventional stud finder for wood or steel is a good choice. Someone on here some time back found the Walabot stud finder worked pretty good.
Old 12-18-21, 03:25 AM
Tolyn Ironhand's Avatar
Received 708 Upvotes on 601 Posts
Here is the one I carry in my everyday pouch: https://www.homedepot.com/p/C-H-Hans...B&gclsrc=aw.ds It works very well.
Old 12-18-21, 07:11 AM
W
Received 60 Upvotes on 52 Posts
How thick are the wall coverings? What material?
Old 12-22-21, 08:48 AM
B
It looks like 5/8" sheetrock but could be more.
I have one of these but it wasn't strong enough. And I'm skeptical of the stud spacing as I found the dry wall seems and figured that would be a stud.
Old 12-22-21, 09:01 AM
Received 754 Upvotes on 659 Posts
Worst case scenario you drill a small hole where you think the stud is. Small holes are easy to repair.
