Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Drywall ceiling with this truss system?
Old 02-23-22, 05:56 PM
P
Hello- hopefully a simple question for the experts… would I be ok to install insulation and Sheetrock to the strapping on the underside of this truss system? I do not have any specs on the detached garage but assuming these are engineered trusses… the bottom chord is 3 2x4s spliced with that (tension?) plate thingy. Will these things support the weight of a ceiling even though they are not continuos bottom chords?
TY
Old 02-23-22, 06:05 PM
XSleeper's Avatar
Received 1,744 Upvotes on 1,568 Posts
Yes, but you haven't told us how far apart the strapping is. As long as it's not more than 24" on center, that's normal and you will need to use 5/8" type X drywall. The bottom chord of the truss is likely rated for 7- 10 lbs per sq ft, assuming a standard drywall ceiling with insulation.
Old 02-24-22, 03:51 AM
P
Thx for reply. The strapping is 16 OC. That gives me good flexibility in choice of drywall right?
Old 02-24-22, 04:39 AM
P
Received 1,849 Upvotes on 1,655 Posts
Yes, with 16" spacing you have the option of using 1/2" sheetrock if it is a detached garage. If it is attached to a house you should contact your local building inspections department to confirm what they want for fire resistance.
