Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Attaching cloud ceiling to popcorn ceiling
Old 04-26-22, 06:32 PM
C
Received 13 Upvotes on 9 Posts
I saw a video on creating a cloud ceiling in our kids' rooms. I have seen videos where they either attach the polyfil or wool to the ceiling using poster board duct taped, double sided tape or stapled to the ceiling. The rooms have popcorn ceiling so I am not sure which method would be best tp use to avoid permanent damage to the ceiling. Does anyone have any insight on which method would be more effective doing the least damage. I watched a video where they mentioned the florida heat and humidity may make the duct tape method less appealing. Can anyone offer any ideas? Thanks.
Old 04-26-22, 09:23 PM
Received 1,197 Upvotes on 1,152 Posts
3M makes some removable tapes but popcorn is about the most easily damaged surface I've encountered so I wouldn't assume anything.
Old 04-27-22, 02:51 AM
Received 754 Upvotes on 659 Posts
I'd be leery of applying anything over popcorn - even paint can be problematic if older popcorn has never been painted before. Humidity doesn't play nice with unpainted popcorn.
If I intended to go forward with this project I'd scrape off the popcorn first.
Old 04-27-22, 04:14 AM
P
Received 1,846 Upvotes on 1,653 Posts
If you use rolled sheets of batting I would just use thumb tacks or push pins. But, as mentioned, popcorn is very delicate so everything is going to damage it or leave a mark.
Old 04-27-22, 05:13 AM
Marq1's Avatar
Received 1,138 Upvotes on 1,032 Posts
No idea what the material actually is but what about mounting to the walls below the ceiling!
