Drilling into plaster?
Old 05-24-22, 11:55 AM
How do I get a screw to stay in this? Thank you!!
Old 05-24-22, 12:05 PM
Received 3,480 Upvotes on 3,125 Posts
Looks like holes for a towel bar bracket.
Plaster isn't forgiving when it comes to mounting things thru it.
You should have wood lathe behind it.
At this point I'd use 1/8" toggle bolts for mounting. You can get them almost everywhere.
You may have to enlarge the holes slightly to get the toggle thru.
They will hold without fail.
Old 05-24-22, 01:24 PM
P
Received 1,840 Upvotes on 1,647 Posts
Toggle bolts like PJmax showed are good. There are also some other styles of insert/molly+ that expand or flip a bar across on the back side of the hole to squeeze the plaster. You do not want a molly or insert that expands inside the hole like is used in brick or cement block.
