Removing painted drywall texture
Old 11-23-22, 04:54 AM
W
Hi. I have a few walls with a thick painted texture. Trying to figure out the best way to remove it. Some of the texture is as large as 1/4 to 1/2 inch off the wall. Thanks.
Old 11-23-22, 05:16 AM
Received 821 Upvotes on 720 Posts
I'd scrape off what I could then skim coat, sand and prime.
Pilot Dane voted this post useful.
Old 11-23-22, 02:35 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
it's nothing more than a thick drywall compound. I removed one wall, not much good scarping did but heavy sandpaper, 60 grit, removed the most, then touched up with regular compound to flatten it out!
Old 11-23-22, 03:02 PM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
It could be venetian plaster for all we know. No way to know until you scrape into it. Joint compound will be pretty soft and comparatively easy to scrape with a paint scraper. Plaster will be much harder.
Old 11-23-22, 05:27 PM
W
Thank you all. This is all very helpful
