Bubbling and cracks in wall?
Old 04-22-24, 10:12 AM
E
Can anyone let me know what the issue is here? Itís so horrible to look at and just want to resolve it asap
Top Answer
04-22-24, 11:17 AM
Pilot Dane
Pilot Dane is offline
Received 2,221 Upvotes on 1,982 Posts
That odd texture right at the bottom corner of a window is suspicious. I would inspect for signs of water damage.
Old 04-22-24, 11:08 AM
XSleeper's Avatar
Received 1,943 Upvotes on 1,745 Posts
Looks like someone with a sponge tried to texture a spot to hide something. So you would start by sanding all that off until it's smooth. The cracks on the corner bead need to be filled, taped, (look into fibafuse) and floated out with joint compound. It will take several coats to get it smooth enough to paint.
Old 04-22-24, 11:16 AM
Received 850 Upvotes on 746 Posts
I'd scrape first and then go with X's advice.
Old 04-22-24, 11:17 AM
P
marksr, sdodder voted this post useful.
Old 04-22-24, 12:11 PM
XSleeper's Avatar
I think we are looking up at the top corner of the window.
Old 04-22-24, 02:49 PM
E
Can I hire someone to do this for me? Thanks all
Old 04-22-24, 03:00 PM
XSleeper's Avatar
Any handyman.
Old 04-22-24, 04:29 PM
T
Received 52 Upvotes on 44 Posts
How old is the house? This looks like plaster to me. This is from water. How long has it been like this? Is it getting worse? What is on the other side of this wall?
The advice above is correct but correct the water intrusion first/
