roof,floor,walls all bad.where do i start?
100 yr old house.rock foundation.3 layers of shingles on roof.bad sagging in the middle.interior walls have bad bulge in them also.floor not level or flat in any direction.HELP.where do i start first.
Received 1 Upvote
1 Post
Yes.
Tear off all three layers of shingles, and replace the rotted roof rafters and sheathing, before laying down your roofing felt and new shingles.
There is a tool that resembles a flathead shovel specifically for removing shingles that will make the job go much faster on the tear-off.
From your description, you probably also need to remove the interior ceiling and walls for a major rebuilding of this laundry room.
I would rip all of the old stuff off and out, and start at the foundation, and rebuild the structure. With the sagging and bulging that you describe (probably from a long-time leaking roof) you also may have termite damage.
I think that you may need a pro general contractor for all of this. They will have the expertise and equipment. You are facing a major project, and if you "dontknownothin", then your role may be limited to demolition and cleanup.
Good Luck!
Good Luck!
