painting textured ceilings
I have a textured ceiling that I painted with Sears Easy Living latex flat paint. It started to peel in areas before it dried completely. WHY??? How do I fix this???
Hello
Looks like you have or had a popcorn ceiling...when you paint it adds weight to the "popcorn"and over time it has dryed and came loose from the sheetrock so it came down...not an easy fix ...but you can get texture is a spray can that can "help" but will never look good...Next best is to remove all the popcorn and skim the ceiling with taping mud and repaint...you could redo the popcorn but it is not cheap and most do not want it any way....Good Luck..
