Stucco Wall Finishes- standard terms
Old 09-16-01, 01:26 PM
Are there standard terms for levels of Stucco Finishes? Maybe as defined by Masterspec, etc.
One guy said #3 sand with elastromeric paint finish...
Thanks,
David Collins
Old 09-23-01, 12:15 AM
some help
Hello
Most term are used to tell what type of finnish product you are using. you need to find out what is avalable in your are should you not know what you want to use...by the way#3 #3 sand with elastromeric paint finish is a good finish to use....Good Luck....
