Soundproofing
Old 12-28-01, 01:20 PM
Bones512
Soundproofing
Am putting up a wall between the kitchen and den to turn the den into a bedroom. Am using 5/8" fireguard sheetrock becaus eI heard that it was better for soundproofing than regular sheetrock. I have the wall up with one side sheetrocked so far. Don't think that it is going to give me the sound deadening that I expected. What can I put in the wall to provide good sound proofing? Thanks.
Old 12-28-01, 03:24 PM
HandyRon's Avatar
Old 12-28-01, 05:27 PM
Insulman
The standard method would be to just install 3 1/2" unfaced fiberglass insulation in the stud cavity's. This will help some and in my opinion is worth the minimal expense.. approx 25 cents a square foot for the material.. anything further gets a bit more complicated and increases the cost..
a double wall will give you the best sound deadening if your willing to lose the floor space.. build two seperate walls and leave 1" space between..
good luck
Jim
Trackbacks are On
Pingbacks are On
Refbacks are On
