Bull Nose Corner Bead
I am going to install bull nose corner bead on som new drywall. The corners that just run to the ceiling are not a problem. How do I deal with the places wher the corners meet, around sofits and around entry ways.
Bullnose corners are usually metal, or metal covered with drywall tape therefore you must use a good pair of sheet metal shears, the kind that cut curves are best, and cut a miter at the joint. If you're not expeinced at this type of thing you may want to experiment with a couple of small pieces until you find the right angle to cut them at so the meet smoothly at the edges. Good Luck!
