Repair and repaiting walls
's Avatar
02-06-02, 07:02 AM   #1
I am replacing vanity and sink in guest bathroom, the original sink was glued directly to the wallboard and when it was removed it took a LOT of wallboard with it. I patched and sanded the wall, applied primer and painted, but now if you look at the wall you can clearly see the smoothness where I did the repair work compared to the textured feel of the original wallboard. Is there anything I can do to correct this??? Thanks!!!
coops28's Avatar
KS
02-07-02, 08:40 PM   #2
I'm not sure if you have this problem or not but a lot of times a smaller nap roller was used on the patch. If you think it might be that use a large nap roller to match the existing paint.
