patching drywall
patching drywall
we've got a sunroom that was drywalled VERY poorly. the tape on all the joints is peeling up, and it looks horrible! now, to repair this, should i simply remove the old tape, and redo?? i'm assuming i should put on some compound, apply the MESH tape, put on some more compound, then go back and sand?? do i have all the steps right here?? THANKS!!!
You are on the right track. Definitely remove all loose tape. If you use mesh tape you don't have to apply mud first. It sounds like, since it's such a bad job, that you will have to feather the bad joints out pretty far to cover the uglyness. Take your time and you will be fine. It may take a few coats too.
thanks for the tips!!
one other question . . . this room gets pretty hot in the warmer months. now, would that cause the paint to "slide" in a small U pattern on the wall?? i don't see any stains, and the drywall feels fine, so i really don't think it's water damage.
I've never experianced that. I'm not a painter so I dont know. But if it gets hot and humid in that room make sure your drywall is sealed really well or the moisture will damge your drywall.
