Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Can I change "bumpy" walls to smooth wall finish?
Old 02-11-02, 09:46 AM
jcerri
Smile Can I change "bumpy" walls to smooth wall finish?
Hi,
My girlfriend and I are looking at condos in Northern CA and all that are in our price range have a "bumpy" or "splattered" finish with quarter-size splotches of drywall mud all over the walls and ceiling. We both love the "smooth-wall" look and I was wondering how to change the walls to this finish.
Thanks,
Joe
Old 02-11-02, 02:13 PM
coops28's Avatar
Sounds like you have "knock down" texture on the walls and ceilings. You will have to skim over that to get it smooth.
Old 02-13-02, 09:41 AM
jcerri
Thanks
Thanks for the info. Would you use a standard out-of-the box joint compound, or mix water into it? Also, would any sanding or washing to rough-up or clean the surface be necessary?
Thanks,
Joe
Old 02-13-02, 02:32 PM
coops28's Avatar
I would use pre mixed joint compound. You can add water to it or use it right out of the box. Your choice. I wouldnt add more than a cup of water per 5 gallons. I think you could go over what you have with little prep. You may want to scrap the walls to get any goobers sticking out off first.
