Luan Plywood beams
Doctorhifi's Avatar
03-18-02, 08:39 AM   #1
Doctorhifi
Luan Plywood beams
I am making false beams for a ceiling. Is there any reason I can't build them out of 1/4" Luan plywood, then skim coat the wood with mud when I mud & tape? Just want to make sure the mud isnt going to react with the wood or something and fall off eventually. Thanks
coops28's Avatar
KS
03-18-02, 11:46 AM   #2
It would be a lot cheaper if you just make a frame then put drywall over it. But if you go the other route you shouldn't have a problem. Make sure you seal the mud with a good stain blocker. Sometimes the wood bleeds through. I know it sounds weird but it happens.
