Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Exterior Wall - Removing Clapboard & Waterproofing
Old 04-30-02, 11:24 AM
Ira
After a heavy rain I discovered that I need to change the grading of my property. Unfortunately my clapboard ends only a few inches from the ground at the top of the foundation. It appears that I will need to remove a few of the boards, waterproof somehow and then backfill. Any suggestions on how to go about this job?
Old 05-08-02, 06:35 PM
woodbadger
You will be much better off if you escavate and put down drain tile.
Note: wood siding should be at least 6" from soil.
