exterior siding
exterior siding
on an exterior wall higher than eight ft. with T-111 siding what is the proper way to install z flashing between the lower and upper courses?
Received 1 Upvote
1 Post
Top of the Z behind the upper piece and the bottom of the Z out over the outside of the lower piece. Overlap the Z a bit where the Z strips meet along a run.
The idea is to keep water from getting behind or into the top of the lower sheet.
Good luck!
Mike
Good luck!
Mike
