water heater noise
water heater noise
when we run the hot water in the bathroom closest to the water heater the pipes shake. It sounds as if the pipes are rattling. How do I fix this? Drain the heater? Thank You, Steve
First, check your water pressure, this could be the issue.
Also, it might be caused by a loose washer on the faucet you are turning on.
Water heaters should be drained at least once a year to prolong the life of tank.
Received 7 Upvotes
Hello: ufg8r85
Water heaters should be flushed yearly to stirup any sediment that settles on the bottom of the tank. To accomplish flushing, help and information, methods and reasons can be found at the link provided below.
http://forum.doityourself.com/showth...hreadid=134483
