Is Electrical Hookup Universal for Water Heaters
Old 03-01-05, 11:54 AM
intensedrive
I was wondering, Im replacing my 40 Gal Electric hot water heater and was wondering if the electrical hookup is universal or is a possibility that it might need to be changed
Old 03-01-05, 05:54 PM
h2o heater
If your existing hook-up is old enough, it may have 2 sets of 220 volt circuits
from the panel box, into the water heater. Your new heater will only need
one such circuit, as the heating elements operate in sequence , rather than
simultaneously, as the old ones did. Just follow the instructions that come
with the new unit and disconnect the unused circuit at the power source.
Oh, if your water heater panel is on a seperate meter, it's illegal to use the
left over circuit for someother use.
Old 03-01-05, 06:15 PM
Mike Swearingen's Avatar
Or your water heater could be on a 20 amp circuit, if old enough.
It should be on a dedicated 30 amp circuit with 10/2-with-ground wiring. Both insulated wires are 120v HOT, and it doesn't matter which one is connected to which insulated wire on the water heater. The bare ground wire goes on the green ground screw. There is no neutral on 220v.
Good Luck!
Mike
