In or under?
Old 12-28-05, 02:20 PM
In or under?
I have aquired a mobile home that has the water heater in a closet in the kitchen. My question is if I move it into the crawlspace below will I notice a differance in my utility bill? How much realistically? What about insulating it, will that make it equal out?
Thanks,
Steve
Old 12-28-05, 07:22 PM
T
I plead the fifth. I refuse to go under another trailer. Last time the cobwebs, cat dung and insulation stuck with me all day.
Old 01-04-06, 10:29 AM
Well I'll be doing this myself so my insulation, cobwebs and cat dung won't be bothering you at all.
Old 01-04-06, 10:41 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
I don't think moving it would raise the utility bill unless you are in a really cold area. You can certainly put an insulation blanket on it. You could also build a shed type enclosure on the outside wall of the home. I have seen this done to use a gas water heater. Good luck.
