water in our gas line to our pool heater.
Old 03-07-07, 12:05 PM
A
We recently discover that we had water in a gas line going to our pool heater. American Home shield doesn't cover underground gas lines so I was wondering if anyone knew how to deal with this kind of problem. Is this an expensive problem to fix? Any help would be greatly appreciated.
ANDREW
***Moderator's note: Multiple threads created in Plumbing and Piping topic, Appliance-Gas topic and Pools, Spas and Hot Tubs topic have been deleted. This thread will be moved to the proper topic if need be***
Last edited by DIYaddict; 03-07-07 at 01:15 PM. Reason: Email address removed for your protection and so your email will not be filled with spam
Old 03-07-07, 12:12 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
LP or Nat gas If Nat.call the gas company there . LP how did it get in there???? This dont sound right at all. More info helps .
Old 03-07-07, 05:44 PM
5
It is possible that it is condensation which has built up. However it is equally possible, of maybe even more likely, that you have a rusted out underground pipe. You would need to get a plumber in to do a pressure test on the pipe to find out.
