Gas Hot Water Heater for Crawl Space
Old 11-15-07, 10:22 AM
A
We need to replace a gas hot water heater installed in a crawl space. Height of the one in place is approximately 35 inches. Who manufactures units of this dimension? Thanks
Old 11-15-07, 07:45 PM
Received 3 Upvotes on 3 Posts
Did you do any google research??
http://www.epinions.com/Water_Heater...r_Heater_31226
I don't know the height
Old 11-16-07, 06:30 AM
A
Yes. Height of present unit is 35-36 inches, in crawl space with virtually no additional room.
Old 11-16-07, 03:52 PM
H
Aside from the actual height of the water heater, don't forget to leave provisions for your exhaust flue pipe. Most water heater manufactures require a 6 inch minimum straight rise coming off the draft hood, then a minimum 1/4 inch per foot pitch from there.
Too many times I see an elbow attached directly to the draft hood and too many times I see the exhaust (carbon monoxide) spilling into the house.
