The horror of (Triangle Tube Prestige Installation)
  #41
Old 01-08-11, 05:20 PM
Originally Posted by ErikEHanson
Could fluctuations in the inlet gas pressure be causing this?
Inlet to what? Your gas fuel valve has a pressure regulator built into it.
  #42
Old 06-23-11, 11:51 AM
V
My prestige triangle tube boiler was flooded (lower part of, control panel)
I have a prestige triangle tube boiler that was brand new and never hooked up (yet) and the lower part of it (where the electronics/control panel is) was flooded (about 6" of it).
Anybody know if I should fire it up (try it out) or not? I've been told by a few heating contractors that since it was not connected (ever hooked up) and "on" when it flooded it's worth a try.
Another heating contractor says that it could be dangerous as the gas could get stuck and cause a fire.
Does anyone know if I can just replace the electronic parts below (in lower part) and what all I should replace there (only the bottom 6" or so flooded).
Thanks! ;-x) - Virginia in Stanwood, WA
  #43
Old 06-23-11, 03:18 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
OK, I messed up... moved the wrong post to here and now can not move it back... would mod please re-route this thread back to the boiler forum ? Thanks...
