New gas water heater roars
Old 02-01-08, 01:12 PM
D
I have a new gas water heater and when i use the hot water the tank makes a LOUD ROARING sound. Thanks for any ideas.
Old 02-01-08, 03:14 PM
5
By any chance are you in LA/Orange/Riverside/San Bernadino county area?
Old 02-01-08, 07:30 PM
Received 1 Vote on 1 Post
Sounds like the burner kicked on. Or are you saying you believe it is excessive? What brand and is it?
Old 02-02-09, 04:41 PM
I have a similar question regarding my new water heater. I just had a Reliance 40 gallon natural gas water installed and when the burner turns on it seems to burn/heat louder than my old one. When the water heater starts to heat, do some models sound louder than others? The pilot doesn't go out and I always have hot water.
Old 02-04-09, 09:39 PM
SeattlePioneer's Avatar
A typical cause of a "roraring" gas burner is an excessive amount of primary air being drawn into the burner because the air shutter is open too far.
Can't recommend you adjest that yourself, since Bad Things can happen if it's improperly adjusted. I'd contact the installer who put in the water heater and ask them to check and adjust it, though.
Old 02-05-09, 08:21 PM
I doubt if this will go anywhere....this is a year old post
