How do i wire 2pole sqare d breaker for 240v water heater?
Old 07-22-08, 09:17 AM
B
do i have the right wire? i dont know. breaker has two connector screws for red and black wires. And the box has a bus bar and a ground bar. Thats 4 wires right? the water heater has a black and red wire and a ground screw. that equals 3. i dont get it. which wires go where. I have the right breaker and the wire is rated 600v romex. do i just use 3 of the 4 wires. which and how. I dont want to fry anything. and yes i turn all the power off at the box under the electrical meter outside. I'm thinking that i wire red to red. black to black. and (green)ground to ground. will that do it. what about the white and bus bar. confused?
Old 07-22-08, 09:50 AM
F
The white wire and neutral bus is not used with a 240 volt water heater. Put a wire nut on the unstripped end of the white wire or clip it off at the cable sheath on both ends.
