Thermostat Question ?
Old 08-15-08, 03:46 PM
The old thermostat on my water heater has only one disc on the back but I cant find a replacement one with just one disc.
Its a APCOM WH8S which I cant find either.
Is it OK the use the ones with 2 discs as long as I get one with the same number of contacts (screws)?
Old 08-15-08, 06:03 PM
plumbingods's Avatar
I am pretty sure what you are showing me here is an upper the Upper Thermostat with the Emergency Cut Out, (ECO).
I's been a few years...
As long as it looks like that on the top and has the correct amount or screw connections you will be fine. I usually change out all the controls to be safe. I have tested them and two weeks later I am back replacing the other control. Cheap money. The lower thermostat, provided you have one will only have 2 screw connections on it if I remember correctly. Sometimes they put a ECO on the bottom also but it is not needed as long as you have one on the top
Old 08-15-08, 06:13 PM
Thanks Mark! Thats what I needed to know. I actually did replace the lower one too, just in case. it's all working fine I just wasnt sure so I figured I'd ask.
Oh.. and hi neighbor! Im just north of Concord in Boscawen
Old 08-15-08, 06:31 PM
Wow, I was so busy reading the question< I did not even notice you were from NH
If you ever need help, you can e-mail me at
We gotta take care of our own..
Old 08-15-08, 06:49 PM
Thanks Mark! Thats awesome
