Water heater leaking
Old 11-29-08, 08:53 AM
B
Could someone tell my what causes hot water to come out the top of a gas water heater.
Old 11-29-08, 08:56 AM
the_tow_guy's Avatar
Received 264 Upvotes on 215 Posts
Could be leaking from either the inlet or outlet fittings and the t&p relief valve may be mounted up there as well.
Old 11-29-08, 09:03 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Or, as a post a few weeks ago had, your tank could be bad. If you don't find a leak at one of the inlet/outlet or T&P fittings, I'd suspect that.
Old 12-02-08, 11:00 AM
D
Is it leaking from a fitting or through a seam in the tank?
