Where should I drain the water?
Old 03-09-09, 06:20 PM
T
Question Where should I drain the water?
Good Evening,
Where should I place the hose to dispose of the water when I drain it? I do not know if there is any sediment inside the water tank. Should I buy a very fine strainer and drain to the bathtub or should I run the hose directly outside? Any help is greatly appreciated.
Old 03-09-09, 07:46 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
If you want to get rid of sediment, you don't want to drain the tank ---you want to flush the tank under the water pressure and flow available to you.
Attach a hose to the drain of the tank and leading outdoors or to a sink. Turn on the drain valve and let the tank flush out at the maximum water flow available.
From time to time fill up a water bucket to see if the water is running clear --- a white 5 gallon plastic bucket is best for that. When the water runs clear, you are done.
Old 03-09-09, 08:31 PM
T
I am actually installing a new water heater. I am just worrying when I drain the water heater into the bathtub that it may cause a clog because of sediment.....
Old 03-10-09, 10:10 PM
I've never seen sediment in anything like the quantity that would plug up a plumbing system. But I suppose that could happen. If you had a lot of that kind of sediment come out, I would look for a plan B.
