water heater has to be reset every two days
Old 04-16-09, 04:01 PM
D
Question water heater has to be reset every two days
We have put in new elements and two new resets. What could be causing this?
Old 04-16-09, 07:30 PM
P
Temporarily Suspended
Wild guess, power surges? Are the new elements the same specs?
Old 04-16-09, 08:38 PM
plumbermandan's Avatar
sure there isnt something wrong with the electrical?
Old 04-17-09, 07:09 AM
D
Yes the elements were of the same specs
Old 04-17-09, 03:27 PM
Received 871 Upvotes on 762 Posts
What about the thermostat? I have a sears WH that does the same thing and I've replaced the thermostat twice
What happens with mine is the water overheats and then trips the reset button - is that what your's is doing? Mine takes spells, it will work correctly for a month or so and other times it will kick the reset daily. It's been this way for several years. Sooner or later I hope to remodel the bath and bed rm next to it and also plan to relocate the WH at that time..... with a new unit
Old 04-17-09, 08:50 PM
marksr, are you sure you elements arent the problem? is the water getting to hot? the elements can short to ground which will allow them to keep heating even if the t-stat shuts off.
Old 04-18-09, 05:24 AM
No, I'm not sure
It's an intermittent problem and I plan to remodel and move and replace the WH then.
