Water heater leaking from bottom
Old 04-24-09, 03:01 PM
C
:madhell:I have a maytag series nine electric water heater that is about nine to ten years old. Water is leaking somewhere from the bottom. I need help.
Old 04-24-09, 04:20 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
If its leaking from the bottom, and not from a connection or valve somewhere, you probably need a new heater. Take the covers off (with power off!) and see if its leaking from an element. If not, the tank has probably corroded through, and replacement is the only option.
