smell in water
Old 05-12-09, 07:16 PM
H
Cool smell in water
I have a gas hot water heater....we have been having a smell in the hot water.....I have been told that it may be the Anode Rod...we have a magnesium rod in now...would like to know so I can solve the problem
Old 05-12-09, 07:25 PM
plumbermandan's Avatar
usually if the smell wasnt there before the anode rod off gasing is a good bet.
you should be able to find an aluminum anode rod. they are a little more expensive but last longer and do a better job
Old 05-12-09, 07:36 PM
H
smell in water
thanks...hot water heater put in this year.....have not have this problem before......Home Depot has a rod....so will give it a try
Old 05-13-09, 01:44 AM
wow. that would be really really fast for an anode to go bad. are you on a well or city water?
Old 05-14-09, 05:06 AM
H
Smile smell in water
I did not have this problem until just lately....I will remove the tube this weekend....drain most of the tank and then see what happens....will let you know
