240 Volt element istead of 230 Volt
Old 11-19-09, 11:48 AM
R
240 Volt element instead of 230 Volt
I have a residential water heater in a mobil home, that needs to have an element replaced. The surrent element is 3500 Watt 230 Volts. All I can find is a 3500 Watt 240 Volt element. CanI use the larger Voltage element without hurtin anything??
Old 11-19-09, 11:56 AM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
Short answer..yes...you will lose a bit of wattage..but not enough to worry about.
Uhhh..wait..is this a residential or commercial application? That MAY make a difference to the Experts (which I am not).
Old 11-20-09, 03:53 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
GG....gotcha. OP said it was residential. RGdorsey, just a little humor between us old guys. Yes, you will be fine with the 240 volt unit. And welcome to the forums!!
Old 11-20-09, 05:50 AM
R
Thanks! I really appreciate it
Old 11-20-09, 09:35 AM
Gunguy45's Avatar
Super Moderator
chandler
I swear that first line wasn't there when I replied...it was edited after my post ya see?
Or maybe my eyes and brain aren't connecting as well as they should anymore?
Oh...and don't be draggin me into that "old guys" club of yours...lol
Old 11-20-09, 07:35 PM
L
Received 1 Upvote on 1 Post
Hey Gunguy, I believe you (for whatever that's worth!!)
230 volt or 240 volt -- it won't matter. That's just two different mfgrs. calling it two different things. Otherwise, it's the same thing. (A double pole circuit running off of the incoming voltage.)
