New water heater venting put in...funny smell now
Old 12-02-09, 06:33 AM
A plumber replaced my 3 inch flu venting with 4 inch yesterday. On all the connection points where he put the 3 screws in he wrapped it with foil tape.
When the heater kicks in after it has been burning a while I get ..... well it smells like a metallic burning smell....I'm thinking it might be the adhesive on the foil tape cooking a bit..it smell pretty bad and the smell carries up my stairway...
Is this something any of you have seen or smelt before? Is it a normal occurrence with foil tape on really hot surfaces? If so Does it go away after a few cycles?
Thanks
Old 12-02-09, 02:37 PM
shacko's Avatar
To the best of my knowledge that tape on your water heater is not rated for the amount of heat that it produces, I would get it off and seal with high temperature caulk,
Old 12-09-09, 06:17 AM
An HVAC guy came out and did just that however still adhesive residue from the tape on there....should this burn off eventually and if so how long?
