Fagor Electric Water Heater Safety Valve Leaking
Old 03-30-10, 02:06 PM
B
I have a fagor electric water (RB-100 N3) in our apartment in portugal.The spring loaded safety valve leaks water when using the hot water.The block has 8 apartments and some of the others are having the same problem.These were all installed last year and have been doing this ever since.
Any help would be appriciated.
Old 03-30-10, 04:13 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Bom dia amigo, I am moving your question to the WATER HEATER forum where you may get better answers. Most of our members are in the US, so we may not be very familiar with your equipment though...
Boa Sorte!
Old 03-30-10, 05:34 PM
5
Not really knowing your system, I will make a general observation. Over here, the safety valve on water heaters will open up on TEMPERATURE too high, OR PRESSURE too high. They are set for 200F and 150 PSI. If either the temp or pressure gets up towards that area, they can start to drip. If the set point is reached, the safety would be full open.
Old 03-31-10, 02:49 PM
NJT's Avatar
NJT
NJT is offline
I wonder if there's a check valve in the line and no expansion tank...
