New Bradford White GX2-25S but getting horrible performance
Hello,
My plumber installed a Bradford White GX2-25S for my 2-story, 3 person, 4.5 bath house and I'm getting horrible performance when even one person is taking a shower. In about 4 minutes the water in a normal shower gets colder and in 6 there is almost no hot water. We have a circulating pump installed as well.
My plumber is ignoring our calls so I called Bradford White. They brought someone in who never saw this model before and claimed everything works as it should. Called Bradford White engineering people and half of them said it should allow one person to take a shower for as long as they want because of the High Recovery system. The other half had no idea.
I've tried different settings on the it and still nothing. Any ideas what the issue could be?
I looked on Wikipedia and I don't think I have one. I included two pictures of what's installed. Pretty much whatever came with the water heater and a blue pump. No other contraptions. The diameter of the gas pipe is 1/2".
ImageShack® - Online Photo and Video Hosting
Oh I see what you have. There should be a check valve under one of your sinks. These are good recircs but use a cold water line at as return. The problem with these is you cant use then if you have a thermostatic shower valve. What valves are in your showers??? Also is the check valve under your sink installed correctly? Its usually the farthest sink. Look.
yes all of the above but I just noticed why do you have a mixing valve?? This could be an issue. What temp is it set at?
Mike NJ
Mike NJ
From what I remember the plumber did something to the following sink or bath tub:
Sink: ImageShack® - Online Photo and Video Hosting
Bath tub: ImageShack® - Online Photo and Video Hosting
This sink didn't have that black connector at the bottom before he was here.
Turned off the pump and doesn't seem to have an effect.
