gas water heater burner assembly replacement
Old 06-27-11, 05:31 PM
G
Angry gas water heater burner assembly replacement
replaced burner assembly and pilot still won't stay lit. Cleaned inside real good and underneath. Turned gas back on and all connections are tight. Light will come on, but won't stay on to increase thermostat. Set it at vacation to ignite with electric starter. WTH!!!!
Old 06-27-11, 05:56 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Hi.
What is the make and model of the heater? How old?
If all is new and installed correctly it may be the gas valve itself.
Mike NJ
Old 06-29-11, 06:23 AM
F
Just curious. With the burner assembly replacement, does that include the pilot assembly too?
