low water
Old 07-03-11, 03:02 PM
Angry low water
my water heat was leaking and i had to replace it with a new one and i have another problem i am barely getting any water in the restroom are the kitchen before i replace the water heater i had no problem with the water can someone help me out
Old 07-03-11, 03:25 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Hi,
If its only the hot water it could be the valve is partially closed at the heater. If its hot and cold check the aerators at each fixture. Sometimes sediment loosens when you disturb the pipes.
Let us know.
Mike NJ
